When you browse your pictures from the favorites pane and close the program, you expect the program to start up in the favorites pane next time, you start up. But it does not at the moment. It starts up in the directory, last used.
Lars Olesen
When starting last setting should be remembered
lsolesen
Re: When starting last setting should be remembered
A known issuelsolesen wrote:When you browse your pictures from the favorites pane and close the program, you expect the program to start up in the favorites pane next time, you start up. But it does not at the moment. It starts up in the directory, last used.
Similar topic: Save "Tree pane" tab / position. Please continue discussions there.
