1.93: Batch Resize Canvas doesn't work with negative delta
In Batch processing (Tools > Batch processing) you can specify delta values for the Transformation "Resize Canvas". The canvas is resized when specifying positive delta values, but nothing happens if you specify negative delta values. :bug:
marsh
Post by marsh »
Odd. It works perfectly for me.
Width [0] (in the boxes on the left, not %)
Height [-5]
[ ]Keep Ratio
[x]Use above values as size delta
Poition [Top center]
Very strange. This does not work for me - I've tried several times with various image formats (JPG, PCX). :-|
BTW:
Right after pressing "Go" the focus jumps to another window. :bug: Can someone confirm?
oops66
Post by oops66 »
helmut wrote:Very strange. This does not work for me - I've tried several times with various image formats (JPG, PCX). :-|
BTW:
I have tried on a jpg with "negatives values", "as size delta" and "center", and that works too without to jump to another window.
Will be fixed in 1.93.2
xnview wrote:Will be fixed in 1.93.2
What will be fixed? The negative value problem or the window focus problem? Or both?
The negative value, i have not the problem with focus
In 1.93.2 the negative values work.
But:
When specify +5 the canvas is enlarged by 5 pixels. But when specifying -5 the image is cropped 10 pixels. I think that's a bug. :bug:
helmut wrote:In 1.93.2 the negative values work.
But:
I can't confirm. If you use top-left +5 add 5 pixels, and -5 remove 5 pixels
