When displaying or converting .pse (PSEG3820) images, XnView incorrectly displays a small white strip at the bottom of each image where actual image data should be.
This problem can be verified by installing the free IBM AFP Viewer Plugin from [url]http://www-1.ibm.com/support/docview.ws ... d1P4000233[/url] and viewing the same image from within your browser (Firefox or Internet Explorer).
For a comparison see the following screenshot: [img]http://steinboeck.wikidot.com/local--fi ... Plugin.jpg[/img]
The image on the left-hand side is what is shown/converted by XnView, the image on the right-hand side is what you can view with the IBM AFP Browser Plugin. The right-hand side is the correct representation.
If needed, I've provided a ZIP archive (44 files, 2 MB in total) of a bunch of .pse (PSEG3820) files: [url]http://steinboeck.wikidot.com/local--fi ... EG3820.ZIP[/url]
.pse (PSEG3820) Files Display Incorrectly (White Strip)
ErichSteinboeck
Re: .pse (PSEG3820) Files Display Incorrectly (White Strip)
Ok, i'll check
