Comment only for one data file, not for all marked
Gast Gerd
Post by Gast Gerd »
It is not possible to set a comment for more than 1 data file at the same time. The button "write all selected" doesn't work any more in version 193.1.
Re: Comment only for one data file, not for all marked
Gast Gerd wrote:It is not possible to set a comment for more than 1 data file at the same time. The button "write all selected" doesn't work any more in version 193.1.
Yes a known bug
Post by Guest »
xnview wrote: Yes a known bug
Sorry, and Thank You for your quick answer.
Nevertheless, with or without this bug, XNVIEW is great.
