very often XnView crashes when saving a .AI or .PDF in a folder that is also open in the XnView browser. To avoid I have to change folder in browser pane before saving from my other software. Has it something to do with Ghostscript?
Crash while saving .AI or .PDF
Troken
Re: Crash while saving .AI or .PDF
Hum, perhaps xnview try to load it (with ghostscript) before the saving in the other software is finished....Troken wrote:Hi,
Troken
Yes, that might be it. I think the crash occurs during the save process. Can the problem be fixed you think?xnview wrote:Hum, perhaps xnview try to load it (with ghostscript) before the saving in the other software is finished....
I'll try, i can't know when the file is completly saved....Troken wrote:Yes, that might be it. I think the crash occurs during the save process. Can the problem be fixed you think?xnview wrote:Hum, perhaps xnview try to load it (with ghostscript) before the saving in the other software is finished....
Troken
I understand, maybe a delay of some sort?xnview wrote:I'll try, i can't know when the file is completly saved....
