1.93.2: Browser->FullScreen Crash w/1.93.1 INI
JohnFredC
Post by JohnFredC »
My 1.93.1 INI causes a crash in XnView 1.93.2 when I attempt to display a thumb in full-screen mode with the middle mouse button.
The image displays correctly in full screen mode, but XnView "encounters a problem and needs to close".
Displaying full screen from the viewer does not crash!
Edit:
Also, the mouse pointer is hidden until the crash dialog appears, which may take a second or two.
John
SinMike
Post by SinMike »
The same in my case. Btw, when creating 1.93.2 version INI - the same crashing occured. Fullscreen shows bad filename if it is in russian (I mean filename, not xnview language). In viewer mode it's OK - no crash, correct filenames.
Re: 1.93.2: Browser->FullScreen Crash w/1.93.1 INI
Could you send me your .ini?
JohnFredC
Post by JohnFredC »
A zipped version of my INI is here.
John
SinMike
Post by SinMike »
I've sent it to your contact adress
Post by Guest »
JohnFredC wrote:My 1.93.1 INI causes a crash in XnView 1.93.2 when I attempt to display a thumb in full-screen mode with the middle mouse button.
Edit:
Confirm. Fully same :(
JohnFredC wrote:A zipped version of my INI is here.
Confirmed. :bugconfirmed: Easy to reproduce with the above .ini file.
xnview.exe has 13h:28 as created time ??
JohnFredC
Post by JohnFredC »
Mine copy says 13:29
John
JohnFredC wrote:Mine copy says 13:29
So the good version. The crash is only with the middle mouse?
Ok, i have it. Is it possible to send you a version to be sure?
JohnFredC
Post by JohnFredC »
Absolutely... !!!
John
JohnFredC wrote:Absolutely... !!!
Could you send me your email by PM, please
JohnFredC
Post by JohnFredC »
Done
John
JohnFredC
Post by JohnFredC »
Hi Pierre!
The test version of XnView you just sent me (dated 3/26/98 20:30) fixes the bug discussed in this thread.
Thank you!
John
