is any parameter availible to cut off (do not take over) the exif data from the jpeg-file while Conversion (using -resize -o ...)
Thanks Tom
cut off 12800 bytes EXIF Data from JPEG while conversion?
tom*de
Re: cut off 12800 bytes EXIF Data from JPEG while conversion
You have -rmeta or -rexifthumbtom*de wrote:is any parameter availible to cut off (do not take over) the exif data from the jpeg-file while Conversion (using -resize -o ...)
