Thumbnails of Avi files are displayed upsidedown
tck
Post by tck »
Only error display with AVI files shown as captured photo below.
Please click the following captured photo of my problem. (How come the label Insert image[img]http://image_url[/img] doesn't work in forum? Can I use img src=?? )
http://images.snapfish.com/342826672323 ... 4784ot1lsi
How can I fix it?
I am using win 2k Traditional Chinese verison and Minimum version of Xnview.
Thanks a lot~~
By the way, how come each time open photo or start a Xnview, it need to wait about 10 seconds delay?
Re: Inverted Display Thumbnail of Avi files
tck wrote:By the way, how come each time open photo or start a Xnview, it need to wait about 10 seconds delay?
Try using the Windows registry for saving the options, see posts for more details
- Slow starting and quitting (1.70.2 and above)
- 100% CPU usage when exiting
for details.
tck
Post by tck »
for details.
Woo!! You are man... after I switch on this in tools-->option-->Install (You know , at first I still need to find where's this option item mention by others..Haha.. if I can upload the photo {I don't know why it's fail to use the and the code doesn't work...Can I use img src ?}, it would be help for others have the same problem)
The photo of setting to be modified is shown in here:
http://images.snapfish.com/342827392323 ... 8697ot1lsi
The speed of opening of Xnview.exe <1s (I do believe it's really faster than ACDSee)
Open photo with Xnview about 1~2sec (maybe coz my win2k with P2 Only :P )
I try to turn off the antivirus software NOD32 and a resulf of test comes out that there's no obvious difference with turn off and on. So there's no interference occur.
By the way, why there's such a option for choice? When we need to turn it off?
On the other hand, is there a solution for the inverted display thumbnail of AVI files?
Thanks again~~
tck wrote:at first I still need to find where's this option item mention by other ...
Sorry, thought the location of the setting was listed in the threads. The setting is named "Use registry to save options" and can be found in "Tools > Options > Install".
The .ini files have various advantages, please have a look at the discussion in the threads listed above and continue those threads if needed.
tck wrote:if I can upload the photo {I don't know why it's fail to use the and the code doesn't work...Can I use img src ?}, it would be help for others have the same problem
This board does not allow uploading of images. I guess that the link to your images do not work because they don't have .jpg, .gif, or .jpg extension. As you can see above, there's a sort of notation for describing menus, which works quite well for most users.
tck wrote:On the other hand, is there a solution for the inverted display thumbnail of AVI files?
No idea on this one.
- Are you using XnView Version 1.74?
tck
Post by tck »
helmut wrote:...
Yeah, I am using 1.74(Oct 11,2004) Libformat version 4.25
Dreamer
Post by Dreamer »
Try to uninstall all in one codec pack (or other, many codecs in one), or divx/xvid and install ffdshow (divx and xvid included)
Also try a standard (or complete) version of xnview (zip file - no need to install, also freeware)
Dreamer wrote:Also try a standard (or complete) version of xnview (zip file - no need to install, also freeware)
The plug-ins which are part of the standard/complete package might have some affect, that's true (just guessing, Pierre should know), so it might be worth a try. Should be also sufficient to download the plug-ins, only.
Note: In XnView, menu "Info > Plug-Ins-Information" on can see which plug-ins are installed.
tck
Post by tck »
The plug-ins in the standard/complete package might have some affect, that's true (just guessing, Pierre should know), so it might be worth a try. Should be also sufficient to download the plug-ins, only.
I try download a standard version, file name is XnView-win-en.exe after install with plugin (error again) and then unstall.
REinstall in different directory and without any plugin(help/Mpeg/Jpeg2000).
Error again.
I will try a Complete version later.
tck wrote:I will try a Complete version later.
In case you have a slow modem connection:
Downloading and installing the Plug-In package should be adequate. But there's little hope that this fixes your problem.
tck
Post by tck »
Just downloaded ffdshow and installed it (I have removed all divd encode software on my computer before installing ffdshow)
Then...error again...hehe...
I wonder what's difference of exe and zip version, exe has an install interface, but zip version can run the program directly ?
Anyway, the minimum small version is enough for me to use.
Is it just the thumbnails of AVI files which are upsidedown (and blue?) or is it also when opening and playing AVI?
tck
Post by tck »
helmut wrote:Is it just the thumbnails of AVI files which are upsidedown (and blue?) or is it also when opening and playing AVI?
It just upside down and blue in thumbnail display, it can open and play correctly in preview embed panel in Xnview.
Yes, currently a known bug :bugconfirmed:
