Limitations of the module Vissudhi for web-sites
OMT
Post by OMT »
I created galleries of paintings on the Web site www.francoise-somson.fr by using the function "web page creation" with the module Vissudhi flash viewer.
First, this module Flash is sensitive CAPS / tiny notably in the names of image files.
For example, if in its parameters we put "file0001.JPG" and if the name of the is "file0001.jpg", the image will not be showed.
Second, the accents in the narrative description of the image are not supported (for example, instead of "à" or "è" or ... it appears a little square on the screen for the description).
Finally, the dimmensionnement of the surface for this module FlashPlayer on the screen is not the easiest to configure, but it is still not impossible.
However, I'm satisfy because this module presents the advantage of dynasmisme in its display and a professional look for a WebSite and it supports a various list of browsers and platforms.
To have a look: www.francoise-somson.fr
Is there a possibility in the future versions of XNVIEW to have some corrections about this small limitations ?
