When having two or more images open in multiple tabs, deleting an image duplicates another one.
- Create a temporary directory with two images in it
- Open both images in viewing mode
- Right-click on one of the images and choose Delete...
- See that the other file that was open is duplicated
[1.93.4] Deleting one of multiple images strange behaviour
henktiggelaar
c.wolke
c.wolke
Danny
You can change that in the options under "View". "Only one view per file" or something.c.wolke wrote:yes, you are correct - but is it normal that a tab with the same picture as in the fist tab opens so that you have two tabs with the same picture?
From my point of view, if a tab with picture1 is already opened you don't need to open it a second time.
Regards
Get the bugs fixed, THEN start adding features. It sucks, but someone has to do it.
henktiggelaar
So you're saying this is not a bug but normal behaviour? If so, what is the point of duplicating an already opened image? Don't you think it will confuse a lot of people?xnview wrote:Normal, because you have option/General/Go to next image...
With the option "Go to next image when deleting current" is enabled it should just activate the next tab, not duplicate it...
You mean "No multiple view for same file". This bug happens with this option enabled.Danny wrote:"Only one view per file" or something.
You can open many view of the same picture file, it's not a problem..henktiggelaar wrote:So you're saying this is not a bug but normal behaviour? If so, what is the point of duplicating an already opened image? Don't you think it will confuse a lot of people?xnview wrote:Normal, because you have option/General/Go to next image...
