First of all, XnView is a really great program, but i have a small problem:
When i change a folder, then i see on the right side of the status bar, that the program ist doing something (refreshing the thumbnails?). This is normally no problem, but it prevents the program showing pdf-files in the browser. To view pdf-files i have to wait until xnview has finished its "work" or i must push the "ESC"-Key to finish this "work" immediately.
Then it is no problem to see the pdf-files in the browser.
Do you have any suggestions to stop this "automatic"? (i don't need thumbnails or anything like that)
Mike
Performance problem
Re: Performance problem
You have this problem when you want to view a pdf file in browser-preview?
Do you use AFPL ghostscript?
MiLei
Performance problem
Yes, i have the problem when i want to view a pdf-file in browser-preview. I'm using AFPL ghostscript version 8.54.
Mike
Mike
Which OS , i don't have the problem...MiLei wrote:Yes, i have the problem when i want to view a pdf-file in browser-preview. I'm using AFPL ghostscript version 8.54.
MiLei
Performance problem
It's Windows 2000 with SP 4.
Mike
Mike
