converting ace files
alfredo
Post by alfredo »
i have installed the linux nconvert version and tried to convert ace files. After converting some files a can't convert anymore ace files???
I got this messages: Error: This output isn't possible (not yet implemented) (jpeg) after this command: nconvert -o jpeg loco.ace
I'm wondering about this. The conversion has definitiv worked yesterday...
I could see the jpg's and bmp's from my last session.
Are there any ini or startup files possibly corrupted?
Regards,
Alfredo
Re: converting ace files
alfredo wrote: Are there any ini or startup files possibly corrupted?
No, and for some .ace nconvert has worked one day?
alfredo
Post by alfredo »
Yes, for some files i have seen the converted jpg and bmp pictures and got a success message from nconvert. For now, i can't convert ace files with nconvert.
Loading the ace into xnview and storing as bmp or jpg works! So the ace files are intact.
Is there a way to use xnview as converter by command-line?
Any idea why nconvert is not working?
Regards, Alfredo
Could you send me a sample?
alfredo
Post by alfredo »
xnview,
may be, but i don't know how to attach a file to a messages.
Sorry :(
Alfredo
alfredo
Post by alfredo »
Ok, I have found the error - shame on me. I had mixed the -o and -out option. Sometimes I use -o jpeg and sometimes -out jpeg. The last works...
Alfredo
