How to appoint a created slideshow as a screensaver?
sydstf
Post by sydstf »
Hello, dear everyone, I have a small question about XnView after I search the forum without finding a satisfactory answer.
I want to ask is it possible to make a created slideshow become a screensaver?
I know there's such function in ACDSee that you can create a slideshow and then designate that created slideshow as the screensaver. I already know how to create a slideshow, but I can't find an option in XnView to appoint my slideshow as the screensaver. Is it possible or is there any way to achieve it?
Thank you for all your kind answer in advance!
Best Regards
Dollym
Slide shoe to screensaver
Post by Dollym »
Choose 'Create slideshow'
Select the files you want in the main box, then in the bottom right you'll notice a button to save as EXE/SCR. Press this, then choose to save the resulting file as *.scr (*.exe will come up as your first choice, but change it).
Wait for it to creat and save, and there you are! If you save it in the C:windows\system32 folder, then you can select it as your Windows screensaver using Contol Panel/Display and so on.
Hope that's clear ...
