PageDown doesn't work correctly in slideshow
Dreamer
Post by Dreamer »
PageDown doesn't work correctly in slideshow (*.sld file). If option "Use Random Order" is enabled, mouse wheel / arrow keys are working correctly (random image), but PageDown switch to next image.
Dreamer
Re: PageDown doesn't work correctly in slideshow
Dreamer wrote:PageDown doesn't work correctly in slideshow (*.sld file). If option "Use Random Order" is enabled, mouse wheel / arrow keys are working correctly (random image), but PageDown switch to next image.
Yes PageDown/Up are used to go to the next/previous file, not the random one...
Dreamer
Post by Dreamer »
So is it a bug, or behavior? I think it should be the same for all keys.
Dreamer
Dreamer wrote:So is it a bug, or behavior? I think it should be the same for all keys.
It's the normal behaviour
Dreamer
Post by Dreamer »
OK, but is it also the correct behavior?
Dreamer
Dreamer wrote:OK, but is it also the correct behavior?
Yes, i think (you have the same in acdsee3)
Dreamer
Post by Dreamer »
It doesn't mean it's correct, what other users think?
Dreamer
