Is it normal that I can't rename .mov file while it is playing in the preview pane, or is this a bug?
Thanks!
Brother Gabriel-Marie
Re: can't rename .mov file while it is playing in the previe
Strange, if you try to delete a movie file, the preview is stopped. Do you have the last version?Brother Gabriel-Marie wrote:Is it normal that I can't rename .mov file while it is playing in the preview pane, or is this a bug?
Thanks!
