Slideshow - cursor issue
Dreamer
Post by Dreamer »
- run the slideshow
- move the mouse cursor a bit
- then quickly press left or right mouse button (you can't move the cursor then!)
= cursor is not automatically hidden
Dreamer
Re: Slideshow - cursor issue
i can't reproduce it
Dreamer
Post by Dreamer »
Strange, try to press right and left button quicky - you can't move the cursor then!
Try these settings in sld file:
# Slide Show Sequence
Timer = 16.000000
Loop = 1
FullScreen = 1
TitleBar = 0
Fit = 1
StrechVideo = 0
High = 1
CenterWindow = 1
ReadErrors = 0
RandomOrder = 1
ShowText = 0
Text = <File Index> <Filename>
BackgroundColor = 0
FontName = "Arial"
FontBold = 0
FontItalic = 0
FontHeight = -19
TextColor = c0c0c0
TextBackColor = 0
TextPosition = 0
Effect = 1
EffectMask = 16777215
Dreamer
