Running on WinXP SP2 and starting with original files named like IMG_0001,JPG, Web page Create (XnView 1.93.4; "_Default - Frame" with "No HTML page per picture" and "Copy source images to output folder" both selected) names the resized file (placed in the 'image' dir) IMG_0001.jpg, but references the file in thumb.html (via "#FRAME_PAGE#") as "IMG_0001.JPG".
This works fine locally in WinXP, but does not work when uploaded to a case-sensitive Unix server, where the "IMG_0001.JPG" href can't find the "IMG_0001.jpg" file.
Web page Create: Filename case mismatch
Re: Web page Create: Filename case mismatch
Ok, right the extension is changed...
