Windows Bitmap Error
Yo P
Post by Yo P »
Dear Pierre-e Gougelet!
I am writing to you because I experienced a strange fail with loading Windows Bitmaps. When I try to watch .bmp files directly with XnView they don't be shown. I see only a blank background. Previews are also blank:
Image Image
But if I watch .bmp files through Total Commander with F3 it loads successful:
What could be wrong? Thank you very much for your help!
(I use Windows XP SP2 64-Bit and XnView 1.93.4, if it is necessary.)
32 bits…
:arrow: Yo P
:) Hello !
• I assume you have 32 BPP BMPs, so go to View menu, and disable “Use Alpha channel".
:mrgreen: KR
Yo P
Re: 32 bits…
Post by Yo P »
Clo wrote:I assume you have 32 BPP BMPs, so go to View menu, and disable “Use Alpha channel".
OMG! :o Thanks Clo! 8) (This option wasn't ticked as standard in previous versions, was it? :P)
OFF TOPIC
