Problem loading/reading Gray scale TIFF
_GUI_
Post by _GUI_ »
Hi all,
I am reading a gray scale TIFF, i.e. an image where each pixel value just appears once and all pixels should be interpreted as R=G=B.
I am using 16-bit GflSDK from VB with this code to read it:
Dim GflParams As GFL_LOAD_PARAMS
Dim PtrBitmap As Long
Dim GflInfo As GFL_FILE_INFORMATION
Dim Error As Integer
gflLibraryInit
gflGetDefaultLoadParams GflParams
With GflParams
  .Flags = GFL_LOAD_ORIGINAL_DEPTH
  .Origin = GFL_BOTTOM_LEFT 'Origin is top left
  .ColorModel = GFL_BGR 'Component order like DIB
  .LinePadding = 4 'Line padding on 4 bytes (32bits)
End With
Error = gflLoadBitmap("c:\foto.tif", PtrBitmap, GflParams, GflInfo)
If Error = GFL_NO_ERROR Then
  extGetGflBitmapFromPtr PtrBitmap, GflBitmap
Else
  Exit Sub
End If
Questions:
1. How should I open it and know it is not a RGB but gray scale picture?
2. I have managed to access all the data correctly through Color.Red like this (get the "photo.tiff" image from: foto.tif):
gflGetColorAt GflBitmap, 0, 0, Color	' Get colour at pixel (0,0)
Color.Red -> 548
Color.Green -> 906
Color.Blue -> 564
gflGetColorAt GflBitmap, 1, 0, Color	' Get colour at pixel (1,0)
Color.Red -> 906
Color.Green -> 564
Color.Blue -> 900
gflGetColorAt GflBitmap, 2, 0, Color	' Get colour at pixel (2,0)
Color.Red -> 564
Color.Green -> 900
Color.Blue -> 564
gflGetColorAt GflBitmap, 3, 0, Color	' Get colour at pixel (3,0)
Color.Red -> 900
Color.Green -> 564
Color.Blue -> 910
The values obtained from Color.Red, Color.Green and Color.Blue are not the same, they are cyclic. Just by reading Color.Red I can obtain the entire image data set, but there must be some other way to properly access this kind of images; I guess there must be some LOAD or READ PARAMETER that forces the library to interpret the image as grey scale but I cannot fin which one.
Could you please help?
Thank you very much.
anasrallah
Post by anasrallah »
Hi _GUI_,
Did you find a clean solution for your grayscale images? I'm working an a similar issue, I have 12 bit grayscale images.
btw why aren't you using the following:
With GflParams
.ColorModel = GFL_GREY 'or is this a 255 value grey???
.LinePadding = 2 '2 bytes instead of 4 for 16 bits images
End With
anasrallah
also did you get the loaded image to show on a picture box in VB?
