I would like to have an 'Add Prefix/Suffix' function in the Batch Rename tool.
Let's say I have a bunch of files that I want to keep the names but add a prefix to all:
I want them to add a prefix so they are renamed to be:
I would like to do this in one easy step. The best way would be to have an 'Add Prefix/Suffix' function where the user just activates the Prefix/Suffix function and types in the desired words and then checks either the Prefix or Suffix box and this is added to the existing names.
I could not find a way to make the 'Name Template' function do this easily but maybe I am missing the secret command that keeps the existing name and adds the new characters to the beginning or end.
Thanks!
Add Prefix/Suffix in Batch Rename Function
- Mike Truly
- Contact:
Sincerely,
Mike Truly
Truly Media
http://www.trulymedia.com
Mike Truly
Truly Media
It is possible
The "Insert>>" button will present a list of commands like <filename>.
Just type anything on either side of <filename>
Ex:
[x]Name Template
[added_<filename>_added]
Ex:
[x]Name Template
- Mike Truly
- Contact:
Thank you very much for this. The helpfile was no help when searching for 'rename' and trying to find these mystery functions. Perhaps the helpfile needs to be improved a bit.
Thanks again... I'll give this a try.
Sincerely,
Mike Truly
Truly Media
Mike Truly
Truly Media
