[OK] Batch Rename - start and step numbers
Locked
Dreamer
Post by Dreamer »
Add (to Batch Rename):
- up and down buttons (spin buttons) behind start and step number
- number '1' button behind start and step number (change any number to one)
- ability to change the numbers with a mouse wheel
- ability to change the numbers with up and down arrows (keys)
Thank you!
Re: Batch Rename - start and step numbers
Dreamer wrote:Add (to Batch Rename):
Ok, i'll add it
I think you're suggestions are good. But I really don't want a number '1' button. Spin buttons are GUI standard, but I've never seen a 'Reset to 1' button. I think that this will make the user interface messy and rather confuse people than help.
I think you're suggestions are good. But I really don't want a number '1' button. Spin buttons are GUI standard, but I've never seen a button 'Reset to 1' button. I think that this will make the user interface messy and rather confuse people than help.
Agree for the '1' button
Dreamer
Post by Dreamer »
xnview wrote:Ok, i'll add it
Thanks.
xnview wrote:Agree for the '1' button
OK, I just thought it would be useful... Often I need to rename a large number to 1.
Dreamer
Post by Dreamer »
Added in 1.80 - '1' button is not really important.
Locked
