I need help binding a key to launch this program.
"C:\WINDOWS\system32\sndvol32.exe /R"
I know the command is 1014. I just cant figure out how to get it to work. In the past I've set up 5 other binds for xnview and windows.
hotkeyP help.
Dreamer
And 1
Dreamer
And 1
Can I set up a toggle (or single bind) to select between 'microphone' and 'what you hear' in the recording panel?
I notice the command is 1000 for mic and 3000 for 'what you hear'.
So what goes in the fields? And can I have it done in the background silently?
Command:
Params:
/r 3000
Thats what ive tried so far that isnt working. How can i make it select 'what you hear'?
I found some sites explaining the switches a little bit. /d is the one that specifices the device ID (like wave, what u hear, line-in). But I cant get it to work.
e.g., SndVol32.exe [-R | -D "wave"]
Info on command line switches 1
Info on command line switches 2
Command:
Params:
/r 3000
Dreamer
