Automatically select images after batch processing
Bossman
Post by Bossman »
Hello everyone,
I've recently made the switch from ACDSee to XnView and so far I love it, but there's one small issue that's bugging me:
In ACDSee, after a Batch Resize, the newly created files were selected automatically, but in XnView this doesn't seem to be the case. Which means that my current workflow is:
Resize 100 images -> manually select all the new files -> Rename them
instead of
Resize 100 images -> Rename the new files
Which is, you know, kind of counterproductive :)
Is there any way to get around this particular nuisance?
Yes, I know, I can always select a different output directory for the resized images, but I'm keeping it as a last resort.
Truth is relative. Pick one that works.
Re: Automatically select images after batch processing
Bossman wrote: Is there any way to get around this particular nuisance?
No, what others users think? Created files must be selected?
JohnFredC
Post by JohnFredC »
Perhaps it would be possible to capture the list of newly created files in the batch process and rename them in the next step?
John
Bossman
Post by Bossman »
Well, after some digging I discovered that the solution to my problem can be found in Tools -> Options -> Browser -> Automatically select new files.
Bossman wrote:Well, after some digging I discovered that the solution to my problem can be found in Tools -> Options -> Browser -> Automatically select new files.
Good that you have found a solution and thanks for posting it here. :-)
