1.93.4: XnShell does not seem to respect registry settings
silverfire
Post by silverfire »
I have XnView set to use an .ini file, but when I was poking around to see how to reenable opening XnView with the shell extension instead of MS Paint, I saw that all of the shell extension settings were in HKCU\Software\XnView\ShellEx instead of in another .ini file in the XnView folder.
Is there a separate place to change that setting? I didn't see it in the shell extension's options so I didn't know if that was something I could change.
Re: [1.93.4] XnShell does not seem to respect registry setti
silverfire wrote:I have XnView set to use an .ini file, but when I was poking around to see how to reenable opening XnView with the shell extension instead of MS Paint, I saw that all of the shell extension settings were in HKCU\Software\XnView\ShellEx instead of in another .ini file in the XnView folder.
XnViewShellEx use always registry
