i load an image.
i resize/cut/filter it.
because of the bad paint-filter (;)) i want to add some pixels and choose "open with" ...
now the original file is opened with the other program.
maybe this could be changed, like when choosing "open with", the edited image is temporarly saved to .bmp and opened again in the other prog?
thanks
when 'open with' edited images the original is opened
herr_k.
ckit
- Forum Librarian
foxyshadis ([url=http://newsgroup.xnview.com/viewtopic.php?p=55022#55022]Addons/Plugins/...[/url]) wrote:This might be an unpopular position, but I'd just like to register that my feelings are that a paint plugin should be little more than a tool that saves an image to png in a temp folder (like %temp%), opens a chosen image editor, and when the editor is closed re-imports the image.
