XNView Option "Adjust Zoom if X/Y DPI are different&quo
Jens
Post by Jens »
Hi!
We got the problem that this option seems to be standard in XNView. Tried to find out where XNView stores if I change that option, but couldn't find any file that changed.. Maybe someone can help me? Is there any section in the ini file I can change to deactivate that option?
marsh
Post by marsh »
In xnview.ini, this item will change:
[View]
UseDPIRatio=0
Adjusting things in the most difficult way?
A text-compare program would be useful- 'Windiff' is found on old OS cds, I think.
Jens
Post by Jens »
I did, but diff program didn't show any changes, neither did NetInstall... That's what drove me crazy...
marsh
Post by marsh »
Welcome aboard,
Maybe a problem with OS user permissions? Others will know much more, since I don't use it with native Windows.
Jens
Post by Jens »
Seems to be working on Windows 2k, but not on Windows XP, although the changes in the ini file are correct... strange thing. I'll keep watching
