Hello, I notice that xnview.db is in my profile (i.e. on C:/documents and settings). Is it easy to change the location of XnView application data folder to another location?
Thanks any help.
Erik
xnview.db in profile
oops66
Re: xnview.db in profile
Hello,Erik wrote:Hello, I notice that xnview.db is in my profile (i.e. on C:/documents and settings). Is it easy to change the location of XnView application data folder to another location?
Thanks any help.
Erik
Yes, for XnView.db file under : Options\thumbnails\cache\use folder\custom ... and your_custom_directory.
