Copied 2 colours image pasted as B & W !
:arrow: Pierre
• If I copy a part of an image having only two colours, it's rendered as 1-bit B & W
when I use "Import Clipboard", that's pretty annoying…
• Maybe is it a defect of Win ? It seems that either XnView doesn't parse the colours,
or it doesn't use the right clipboard format…
• When I paste the same content in GFIE, I get the colours alright…
:?: Any clue ?
:mrgreen: KR
ouistiti
Post by ouistiti »
:arrow: Clo
- I can confirm !
The same clipboard content displays the colours alright in GFIE and in PaintShopPro (version 9) when pasted.
Friendly
Paul
1,77245385090552...
Re: Copied 2 colours image pasted as B & W !
could you send me a sample?
See here
:arrow: Pierre
:) Hello !
• I show the sample here below, and that I get when I select >> copy the lower part - only the |_| part,
without the single differently coloured pixel :
¤ Notes :
1. The images above are captured as blown up by 600%.
2. If you copy let's say, a selection containing only pure white and pure red and import it, it's OK.
:mrgreen: KR
marsh
Post by marsh »
Clo wrote: :?: Any clue ?
Just a guess that you are using 16 bit color for your video hardware. ?? :)
Re: See here
Clo wrote: • I show the sample here below, and that I get when I select >> copy the lower part - only the |_| part,
I need the file
You have it
:arrow: PIerre
:) Hello !
• You might have it, it's on the test-skin main bitmap I sent you one hour later…
• That seems fixed up in the 1.93.6 RC, though.
:mrgreen: KR
