Custom canvas size switched
mxmauro
Post by mxmauro »
If I open 2 or more images in one instance of XnView, apply a custom canvas size to one of them, then, when I want to appy a canvas size to the second image, width and height values appears switched.
Best regards,
Mauro.
marsh
Post by marsh »
That was fixed in beta version. If you see something different with beta, follow-up here or the topic below:
[1.93.4] Canvas resizing switches width & height
mxmauro
Post by mxmauro »
I should use the search better :) Thanks. I'll download beta.
