B3: Ignore alpha channel does not appear to work
silverfire
Post by silverfire »
Checked General\Ignore alpha channel in options and opened a 32-bit BMP. Tried to save as JPEG without doing anything else and resulted in a completely white JPEG file.
RE: * 'Ignore alpha channel' option - http://newsgroup.xnview.com/viewtopic.php?t=14887
EDIT: Restarting the program appears to have fixed the problem, so it just needs to be noted that it requires program restart or something.
Re: B3: Ignore alpha channel does not appear to work
I can't confirm, this option works when i load the file without restarting it
silverfire
Hmm... I can't either...
Not even uninstalling and reinstalling an older version does it.
Oh well - if nobody else gets the random issue, then I guess it's all for the best.
