Hi there, I was wondering if these options exist already in XnV as I have moved across from ACDSee 2.24.
1st one is having an option so that XnW always loads in full screen mode when clicking files in Windows Explorer.
2nd is having the desktop listed at the top of the folders tree view
3rd one is removing the delay when using the arrow keys in the browser when moving up and down.
The program looks amazing and if I can do those 3 things it would be perfect!
Thank You.
2 Q's: Always load fullscreen + Desktop listed on Folders
Rikki
Re: 2 Q's: Always load fullscreen + Desktop listed on Folder
Option/General/Mode starting with a fileRikki wrote: 1st one is having an option so that XnW always loads in full screen mode when clicking files in Windows Explorer.
Browser/FolderTree/Show desktop2nd is having the desktop listed at the top of the folders tree view
INI added in next release3rd one is removing the delay when using the arrow keys in the browser when moving up and down.
Rikki
Rikki
Just installed the new version last night and got the delay sorted out so thanks very much for that.
One last quick question is, is it possible to have the images display as you skip through them in browser and full screen mode. In ACDSee (the old 2.4 version) you could hold the space bar and as the program went through the images it would flash them up on screen as it went (so you could spot where roughly to stop flicking through).
Many thanks
R
Many thanks
R
