When installing XnView without the JPEG2000 plugin, the export dialog still shows the JPEG2000 tab!
Should be removed IMO (to avoid the "Warning - Contact your dealer" message).
SOLVED
JPEG2000 in export dialog even if not installed (SOLVED)
Dstruct
Re: JPEG2000 option shown in export dialog even if not insta
Perhaps the cache for plugins is not updated correctly
[Plugins] section
[Plugins] section
Dstruct
thanks! this was the culprit! shouldn't XnView update the cache automatically if a plugin got removed?xnview wrote:Perhaps the cache for plugins is not updated correctly
Yes, but not hereDstruct wrote:thanks! this was the culprit! shouldn't XnView update the cache automatically if a plugin got removed?xnview wrote:Perhaps the cache for plugins is not updated correctly
