Images dir: c:\Images\
XnView dir: c:\XnView\
I am in c:\Images\, set my batch processing options including output into directory "Processed" (assuming it will be created as a subdir in c:\Images\), save the script to c:\XnView\MyScript.xbs and press Go.
Fault: the directory "Processed" is created under c:\XnView\ (where I saved the script) instead of in c:\Images\.
It seems that the Save script dialog changed the current working dir of XnView.
TIA
Roman
Saving script in Batch process dialog changes current dir
Hacker
