Skins: no backward/forward icons
Post by Guest »
I'm using XnView 1.93.6 and discovered that the go back/forward icons next to the address line do not appear with several skins e.g. Matte DeLuxe. In the configuration I see the icons but when I change the skin they do not appear.
I also realized that all icons are changed once the options are saved, except the ones next to the address bar.
Anonymous wrote:I'm using XnView 1.93.6 and discovered that the go back/forward icons next to the address line do not appear with several skins e.g. Matte DeLuxe. In the configuration I see the icons but when I change the skin they do not appear.
Anonymous wrote:I also realized that all icons are changed once the options are saved, except the ones next to the address bar.
