GflAx .FillColor and EXIF information
bobpanne
Post by bobpanne »
i'm new with XnView and I already love the features. I need to resize pictures for my website in two formats.
  • 1. 210px width, I got it working perfectly. Only the Sharpen function isn't working in GflAx. Is there a change it will function in new releases?
  • 2. 433px width, merge it with another image. This is working great but I also want to add a picture width rectangle with the filename in it. Creating the rectangle and placing the text is working but I cannot set the .FillColor, is this property also not supported?
    Microsoft VBScript runtime error '800a01b6'
    Object doesn't support this property or method: 'FillColor'
    /leukopdefoto-local/images/test.asp, line 36
  • 3. Is it possible to read out EXIF information. Then I can automatically rotate pictures.
I hope somebody can help me with this issues. :D
If most of this functions work I will definitly order your product.
Kind regards,
Bob
