Double click on jpeg files
Post by Guest »
Hi all.
When i double click on a jpeg image in a folder containig other files (exe, pdf, ..) i always receive an error message:
"Format of the file <xxxxx.exe (or xxx.txt, dat, doc) could not be determined"
But I clicked on a jpg file !!!
The program works well if the entire folder has image formats or if i click on gif images.
Thansk !
Re: Double click on jpeg files
And if you drag&drop a picture file on the xnview icon, what's happened?
Post by Guest »
The image is opened correctly into xnview, not in a fullscrren mode but with a tab.
Thanks
Which setting do you have in option/General/Mode when starting...
Post by Guest »
It is 'Normal'
But i wonder why for gif file the double click is ok but for the jpg seems to enum all the files into the directory ...
Thanks
Post by Guest »
Yes !! :mrgreen:
This was the problem .. I did not know that registry item .. I checked only the .jpg items ...
Thanks a lot !! :D
