Minor Bug, GFL SDK 2.82 for Delphi
stolarz
Post by stolarz »
is:
function gflAllockBitmap(BType: GFL_BITMAP_TYPE;
  width, height, line_padding: GFL_INT32;
  var color: PGFL_COLOR): PGFL_BITMAP; stdcall;
should be:
stolarz
Post by stolarz »
or:
  var color: TGFL_COLOR): PGFL_BITMAP; stdcall;
gispos
Post by gispos »
Download the updated lib.pas at: http://newsgroup.xnview.com/viewtopic.php?t=14526
and test it.
The updated lib code is:
  const color: PGFL_COLOR): PGFL_BITMAP; stdcall;
function gflAllockBitmapEx(BType: GFL_BITMAP_TYPE; width, height: GFL_INT32;
  bits_per_component: GFL_UINT16; padding: GFL_UINT32;
I think the color declarations must be “var” or “const”, otherwise the color will not always read correct!
Gruß gispos
