Maximized Browser/windowed Viewer
tannim
Yahoo Messenger: tannimdragons
Post by tannim »
This problem affects two options and has since I've used it.
First, I'll describe what I want to have happen. I want to have the image browser maximized. I want to have the viewer windowed. When I press enter to go to viewer from browser, I want the entire window to resize to the windowed view. When I press enter to go from viewer to browser, I want the window to maximize.
In theory, "Use different position/size for browser and View" should do this. It does not. I press enter in the browser to go to view, then click the restore button to make the maximized window go to windowed view. I press enter to go back to browser, but now the browser is windowed instead of maximized like it should be.
In the beta of 1.93.6, it would work one time and then go back to the way I just described. I could not see any options in the INI file that would affect this behavior. I do not use tabs and I have them disabled. One view window open, no tab view. This is a handy feature for using a picture as a reference while drawing in paintchat.
Also "Remember Last Window Position." doesn't seem to work either.
Re: Maximized Browser/windowed Viewer
I can't reproduce this bug with 1.94.2. When using ENTER, the browser is maximized, and view is windowed...
