XnView & SE : file size dependent preview
moudy
Post by moudy »
hallo everybody,
i have used this fantastic viewer for 6 years. and i think, there should be a option for preview, which makes it depend on the file size.
if the file is too large and without pre-built thumbnail, then XnView and SE should not attempt to generate thumbnail.
this suggestion comes from my experience.
i have a folder with many large pictures(250M+, ps/tiff). whenever i open this folder with XnView, the computer seems to be killing itself. and in this folder i daren't to touch the right mouse button, because SE will let me wait for 1 min.
Re: XnView & SE : file size dependent preview
IN Option/Filelist you can use the max file size
moudy
Post by moudy »
thanks. but it is only for viewer. There is no option for SE.
