Hi Pierre,
could you add a "Cut Off White Borders" checkbox on the "Print --> Best Fit To Page" page? When checked, the picture should be enlarged proportionally so that the page is filled completely.
Cheers
Frank
Print: Cut Off White Borders
Peter2
Re: Print: Cut Off White Borders
But with that some area of picture will be outside the paper??
Peter2
