32 bit BMP is not displayed properly
DanielVV
Post by DanielVV »
Hello again...
Ok i look for that settings in my german version, but i couldn'd find it.
I upload here
http://mitglied.lycos.de/pally/773x510x32.rar
a bitmap wit those 32bits made with HoverSnap v0.8 from www.hoverdesk.net
So tell me if this screenshooter makes wrong BMPs or if i'm too stup.. to use this programs :D
Thanks Pierre, bye from Daniel
Re: Reply to Pierre
Your picture has a bad alpha channel (all is black).
You can view correctly the picture by disabling view/Use alpha channel
and load it correctly by enabled option/general/Ignore alpha channel
