Rotate Pictures
Nikon
Rotate Pictures
Post by Nikon »
With NEF ( Nikon RAW ) files when you are in fullscreen mode, if you view the photos forward, the pictures are not rotated, but when you do it backwards the EXIF rotating works ok. :shock:
v 1.93.6
Thanks for this fantastic Program.
Re: Rotate Pictures
Nikon wrote:With NEF ( Nikon RAW ) files when you are in fullscreen mode, if you view the photos forward, the pictures are not rotated, but when you do it backwards the EXIF rotating works ok.
Just recently I've read about a similar problem but I can't find the topic. My guess is that when caching the automatic rotation using the EXIF orientation gets mixed up.
Re: Rotate Pictures
Re: Rotate Pictures
Yes, that's the topic. Thank you, XnTriq! :-)
