is it possible to use the - Extract Channel - function with the
- Batch Processing - Transformation - dialog?
I often have to extract one channel from a fairly large amount of images.
So it would be great to use extract channel with batch processing!
By now I have not found a way to do in XnView.
Thanks a lot and best regards,
Frank
Using Extract Channel with Batch Processing Transformation
Re: Using Extract Channel with Batch Processing Transformati
Ok, i'll add it in batch processing
FraGE
Hi Pierre,
that's great!
You are doing a brillant job!
I'm saying this not only you are adding it!
Thank you very much and
best regards,
Frank
that's great!
best regards,
Frank
