Batch Convert Dialog - Add/Sub-Directories doesn't work
pbrown01
Post by pbrown01 »
XnView for Windows, Ver 1.82.4, Libformat Version 4.57. In the Add dialog, checking "Include Sub-Directories" doesn't work as the dialog will not allow you to select a directory in the first place.
Re: Batch Convert Dialog - Add/Sub-Directories doesn't work
Drag&drop folder in the file list
