Batch Convert Dialog - Add Folder doesn't work.
pbrown01
XnView for Windows, Ver 1.82.4, Libformat Version 4.57. The Add Folder dialog doesn't seem to work, at least for the case where the target files are PCD (Kodak Photo-CD) format.
Re: Batch Convert Dialog - Add Folder doesn't work.
Yes add folder add most used file format (jpg, tif, png, gif, ...)
Age Pi
