Some usefule (for me) questions
Grincheux
Post by Grincheux »
How can I know which options are available when saving a file ?
I explain : If I want to save a JPEG file I have compression and quality options to set, but what about others formats ?
Compresion generally is not used with a BMP file, I would not like to show a compression option for a file format which does not need it ? What would be thinking the user about such software ?
Is there an other up to date help file ?
What are the filters options ?
:twisted: Thanks
Kenavo.
Re: Some usefule (for me) questions
Grincheux wrote:How can I know which options are available when saving a file ?
Yes, currently it's not easy. You must see in XnView what is used
no
Which filter?
