Reduce extracted tif images
boxig
Post by boxig »
I use this to extract images from tif:
-xall -o test.tif source.tif
Is there a way to get a half size images (reduced to 50%) ?
Thank you
box
Re: Reduce extracted tif images
you can use -resize
boxig
Post by boxig »
I tried it but the result is very ubclear.
Thank you
box
You can change the resize method
boxig
Post by boxig »
-dpi 100
This solved the problem.
BTW, is there a way to save only specific pages from the PDF ?
Thank you
box
