xnview 1.93.6 hangs after first click
stormy1777
Been using program for several weeks, and love it. It works fine on 4 identical PCs.. however today it stopped working on one of them.
Just hangs after first click. I tried reinstalling, uninstalling, rebooting, etc. no matter what, after first click on the folder pane or an image, it just HANGS.. you must kill it. trying process monitor and I see nothing interesting in the output.. I'll try reg-mon tomorrow, but any other tips??
no cpu, nothing, just hangs.
this is win2k sp4 with latest xnview-english. Like I said, it has worked perfectly fine on this PC for several weeks. not sure 'what changed'...
Thanks.
Thanks.
stormy1777
xnview 1.93.6 hangs on opening invalid PNG image (orig jpg)
Ok, I figured it out...
Take a jpg image, rename it to .png, now go to that directory, and xnview will just hang, forever.. no cpu, no nothing.. just hangs..
I'm very happy I found the root cause of the hang!!! but others may have difficulties..
marsh
b1: Renamed image stops thumbnail rendering
I don't see it anymore (on emulator), maybe it is only on Win2k?
stormy1777
YES! exactly the right thread!
I'm on Win2k, and it's very easy to reproduce:
- Attempt to view a misnamed .jpg (call it .png)
- Make sure there is not already a thumbnail for that image.
- Make sure 'recognize only by extension' is enabled in the options->file list-Misc is ON.
interesting part is that xnview just HANGS.. no cpu, etc.
but now I have a workaround, unset 'recognize only by extension'.
Would still be nice to fix this not to hang...
stormy1777
stormy1777
stormy1777
0. in options Browser->file list->Misc, change recognize only by extension to YES
1. close xnview completely
2. rename a .jpg image you never viewed before to .png remember the folder this image is at
3. startup xnview and on the left sidebar navigate to that folder.
4. it will now hang, only way to get out is kill in task-mgr
I can't reproduce itstormy1777 wrote:0. in options Browser->file list->Misc, change recognize only by extension to YES
Someone can?
stormy1777
To me it happens all the time on all my win2k machines using the above steps. I also asked others to see if they can provide more info from the original thread:
http://newsgroup.xnview.com/viewtopic.php?p=62432
Thanks!
Thanks!
stormy1777
only happens on win2k
I can confirm it only happens on win2k.
tried reproducing with winxp and it's not.. works ok on winxp.
Re: only happens on win2k
Ok, i have found the problem, only on win2k, it's a problem with windows explorer. For other files, i ask system to send the thumbnail. I have some dead lock on windows explorer too on this file too...stormy1777 wrote:I can confirm it only happens on win2k.
