kchikchi
Hello ! Welcome aboard !
• I assume that you mean : “
Auto-scroll” ? It's indeed missing.
- Nothing against, but it could be advanced enough to be used for other purposes.
- For instance, with options to adjust the scrolling speed¦step¦direction, show as loop or not…
according to the specific needs of each user.
- As a workaround, this could be done with a HTML page using the <MARQUEE> marker.
It supports all above-mentioned options.
- However, I didn't test it with very wide images, and it doesn't work properly with Web browsers else than I.E.
Kind regards,
