De-skew color image
lucifer90
De-skew color image
Post by lucifer90 »
Hi
I am waiting for a long time for the option de-skew on color jpg picture
Does this fontion coming soon ? (not in v1.93.6 … only for w&b picture)
Does a plug in or filter exist to do this?
Thanks
________
Subjét: Redresser image couleur
Bonjour
J'attend depuis longtemps la possibilité de redresser les images couleurs jpg
Cette fonction n'est pas présente dans la version 1.93.6 (ne redresse uniquement que le n&b)
Est-ce qu'il existerait un filtre ou un plug-in pour faire ça ?
Merci
Re: Redresser image couleur / De-skew color image
lucifer90 wrote: I am waiting for a long time for the option de-skew on color jpg picture
Not yet, could you post a sample picture?
De-Skewing is a pretty important photo manipulation, which is needed more and more often by more and more people. So I second this.
A first, "small" solution would be showing/hiding the grid in the rotate dialog (not possible in 1.93.6) and to better support manual de-skewing. In a second step automatic deskewing should be supported.
